Problem with Visual C++ 2015
Henry-100
4
Recently whenever I try to play a game on steam it says that I do not have Microsoft Visual C++ 2015. This only started to happen within the last week or so.
I Tried to reinstall Microsoft Visual C++ 2015 from their website but whenever I run either the x86 or x64 the setup fails.
Here is the log file.
[2E34:11A8][2018-01-25T23:04:37]i001: Burn v3.7.3813.0, Windows v10.0 (Build 16299: Service Pack 0), path: C:\Users\Henry\Downloads\vc_redist.x64.exe, cmdline: ''
[2E34:11A8][2018-01-25T23:04:37]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\Henry\AppData\Local\Temp\dd_vcredist_amd64_20180125230437.log'
[2E34:11A8][2018-01-25T23:04:37]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\Henry\Downloads\vc_redist.x64.exe'
[2E34:11A8][2018-01-25T23:04:37]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\Henry\Downloads\'
[2E34:11A8][2018-01-25T23:04:37]i000: Setting string variable 'WixBundleName' to value 'Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24123'
[2E34:11A8][2018-01-25T23:04:37]i100: Detect begin, 10 packages
[2E34:11A8][2018-01-25T23:04:37]i000: Setting version variable 'windows_uCRT_DetectKey' to value '10.0.16299.125'
[2E34:11A8][2018-01-25T23:04:37]i000: Setting numeric variable 'windows_uCRT_DetectKeyExists' to value 1
[2E34:11A8][2018-01-25T23:04:37]i102: Detected related bundle: {f1e7e313-06df-4c56-96a9-99fdfd149c51}, type: Upgrade, scope: PerMachine, version: 14.10.25008.0, operation: Downgrade
[2E34:11A8][2018-01-25T23:04:37]i108: Detected compatible package: vcRuntimeMinimum_x64, provider: Microsoft.VS.VC_RuntimeMinimumVSU_amd64,v14, installed: {8D50D8C6-1E3D-3BAB-B2B7-A5399EA1EBD1}, version: 14.10.25008, chained: {FDBE9DB4-7A91-3A28-B27E-705EF7CFAE57}
[2E34:11A8][2018-01-25T23:04:37]i103: Detected related package: {8D50D8C6-1E3D-3BAB-B2B7-A5399EA1EBD1}, scope: PerMachine, version: 14.10.25008.0, language: 0 operation: Downgrade
[2E34:11A8][2018-01-25T23:04:37]i108: Detected compatible package: vcRuntimeAdditional_x64, provider: Microsoft.VS.VC_RuntimeAdditionalVSU_amd64,v14, installed: {C668F044-4825-330D-8F9F-3CBFC9F2AB89}, version: 14.10.25008, chained: {21134089-9B59-34C8-BE11-929D26AD5207}
[2E34:11A8][2018-01-25T23:04:37]i103: Detected related package: {C668F044-4825-330D-8F9F-3CBFC9F2AB89}, scope: PerMachine, version: 14.10.25008.0, language: 0 operation: Downgrade
[2E34:11A8][2018-01-25T23:04:37]i052: Condition '(VersionNT = v6.3 AND NOT VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)' evaluates to false.
[2E34:11A8][2018-01-25T23:04:37]i052: Condition '(VersionNT = v6.3 AND VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)' evaluates to false.
[2E34:11A8][2018-01-25T23:04:37]i052: Condition '(VersionNT = v6.2 AND NOT VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)' evaluates to false.
[2E34:11A8][2018-01-25T23:04:37]i052: Condition '(VersionNT = v6.2 AND VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)' evaluates to false.
[2E34:11A8][2018-01-25T23:04:37]i052: Condition '(VersionNT = v6.1 AND NOT VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)' evaluates to false.
[2E34:11A8][2018-01-25T23:04:37]i052: Condition '(VersionNT = v6.1 AND VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)' evaluates to false.
[2E34:11A8][2018-01-25T23:04:37]i052: Condition '(VersionNT = v6.0 AND NOT VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)' evaluates to false.
[2E34:11A8][2018-01-25T23:04:37]i052: Condition '(VersionNT = v6.0 AND VersionNT64) AND (windows_uCRT_DetectKeyExists AND windows_uCRT_DetectKey >= v10.0.10240.0)' evaluates to false.
[2E34:11A8][2018-01-25T23:04:37]i101: Detected package: vcRuntimeMinimum_x64, state: Obsolete, cached: None
[2E34:11A8][2018-01-25T23:04:37]i101: Detected package: vcRuntimeAdditional_x64, state: Obsolete, cached: None
[2E34:11A8][2018-01-25T23:04:37]i101: Detected package: Windows81_x86, state: Absent, cached: None
[2E34:11A8][2018-01-25T23:04:37]i101: Detected package: Windows81_x64, state: Absent, cached: None
[2E34:11A8][2018-01-25T23:04:37]i101: Detected package: Windows8_x86, state: Absent, cached: None
[2E34:11A8][2018-01-25T23:04:37]i101: Detected package: Windows8_x64, state: Absent, cached: None
[2E34:11A8][2018-01-25T23:04:37]i101: Detected package: Windows7_MSU_x86, state: Absent, cached: None
[2E34:11A8][2018-01-25T23:04:37]i101: Detected package: Windows7_MSU_x64, state: Absent, cached: None
[2E34:11A8][2018-01-25T23:04:37]i101: Detected package: WindowsVista_MSU_x86, state: Absent, cached: None
[2E34:11A8][2018-01-25T23:04:37]i101: Detected package: WindowsVista_MSU_x64, state: Absent, cached: None
[2E34:11A8][2018-01-25T23:04:37]i052: Condition 'VersionNT64 >= v6.0 OR (VersionNT64 = v5.2 AND ServicePackLevel >= 1)' evaluates to true.
[2E34:11A8][2018-01-25T23:04:37]i199: Detect complete, result: 0x0
[2E34:221C][2018-01-25T23:04:39]e000: Error 0x80070666: Cannot install a product when a newer version is installed.
you were using an older version of the redistributable thats why your install attempt failed.
you can try going to your Programs and uninstall all of the 2015 C++ redistributable. restart
you can let the game install the redistributable for you again or you can go to this site below and intall the appropriate versions manually. restart.
https://support.microsoft.com/en-us/help/2977003/the-latest-supported-visual-c-downloads
try running the steam game again.
if it still refused to install. you will need to run the following below. your windows files may be corrupted. and try again above after its done.
https://www.howtogeek.com/222532/how-to-repair-corrupted-windows-system-files-with-the-sfc-and-dism-commands/
