hi,
recently I bought WD 10EZEX 1TB blue HDD for increment in storage. 1st time the HDD run properly without any issue. When i formatted it (using windows 10) in NTFS format for windows installation every thing is working fine but after restarting the PC for installing windows, I started facing some problem with WD HDD.
1.) unable to install windows, whenever i tried to install windows it get stuck after windows logo disappears during boot... I wait for long to check that may be it take some time to start windows installation but nothing happened, black screen goes on.( tried using windows 8.1 pro CD/USB and windows 7 home basis CD/USB, even tried installing Ubuntu)
2.) I checked my bios, it shows my HDD got detected and of capacity 1000.2GB,
but doesn't work during OS boot or with other HDD (windows installed). I tried using different SATA3 / SATA2 cables, tried different SATA3/SATA2 ports, even tried changing different SATA power cables/ports too... but faced same problem again and again.
3.) I tried to format the disk using with other HDD 2nd time (using windows 10) but it does not let the OS start. windows get stuck on the windows logo and do not run further. HDD with the OS is working properly as I used it daily but when I connect it with WD HDD it got stuck every-time same place.
4.) I tried to touch the HDD physically to check the running vibration and found it's working.
PLEASE tell me how to use my WD HDD
my computer specs:
processor: i3-2120 @3.30GHz
RAM: 4GB
GPU:ASUS Radeon HD 6670 1GB GDDR5
OS: WINDOWS 10 PRO
Motherboard: GIGABYTE B75M-D3H
my computer specs:
RAM: 4GB
OS: WINDOWS 10 PRO
