Problem With Win Xp
bros1987
Hi,
I have a pc with Win XP Pro Installed on a Maxtor Hard Disk, controlled by a SATA Raid Controller Sil3114 by Silicon Image.
When I Connect My WD10EAVS (Western Digital Hard Disk) to my controller and I turn on the Pc No operating system loads and the screen say: Press A Key To Reboot.
Thanks,
Edo
OS: Win Xp
MoBo: Asus P4PE
Controller: Sil 3114
HDD: Maxtor ...
HDD2: Western Digital WD10EAVS
Notes:
Before Today I had linux on this pc and both of the hard disks worked.
Without the WD Disk All works in the right way.
Sorry For my english. :-D
Check the boot order in your BIOS. Sounds like it is trying to use the WD as a primary boot device when plugged in. Set the boot order to the Maxtor on SATA as primary and you should be good to go.
