Question Problem
Sep 9, 2021
Hello guys
My screen is stuttered today on ordinary work without gaming i also noticed it closed automatically and reopen
Is this because a problem in my GPU
Notice : my GPU is GTX 1650 super
punkncat
Dignified
Ambassador
Far too little detail.
What are your system specs?
Are you seeing high CPU usage in Task Manager even when you aren't actively doing things?
RAM use? Number of open processes that you can account for?
Is it only a graphic artifact, or is it that the computer isn't keeping up with the process...like for instance if you are running a lot of programs, using up all your RAM and CPU utilization and it's stuttering to keep up, or such that weird stuff is displaying, black (or other color) screening and such?
Run a virus scan?
Sep 9, 2021
Thanks for your answer
My specs
Core i7 4790
Ram hyper x 16 gb ddr3
Gtx 1650 super
Win 10 64 bit
This stuttering happens when i work on Microsoft word
No load on CPU
Gpu temp 36 degrees
My screen turns black
punkncat
Dignified
Ambassador
What power supply?
Have you check another monitor or have a TV you can connect to to test? Different cable?
Check Event Viewer, particularly under the critical and error tabs. Open a search window to check the codes.
Event 41?
In some cases Reliability History can show pertinent information as well. Typically much more general than event viewer.
