D donnyberger23 Honorable Dec 13, 2012 43 0 10,530 Dec 24, 2012 #1 I'm going to buy a HD 7770 but i just realized my monitor only has a vga port. Is there anything i can do? I've noticed that the HD 7770 only has DVI and Hdmi.
Sunius Splendid Dec 19, 2010 9,582 0 31,960 Dec 24, 2012 #2 You could get DVI to VGA cable or adapter. They are pretty cheap. http://www.newegg.com/Product/Product.aspx?Item=N82E16814999201 http://www.newegg.com/Product/Product.aspx?Item=N82E16812119465 Upvote 0 Downvote
dingo07 Splendid Jan 5, 2012 3,238 24 21,465 Dec 24, 2012 #3 I would get a new monitor that has at least 1900x1200 resolution Upvote 0 Downvote
zdbc13 Distinguished Feb 7, 2012 1,887 0 19,960 Dec 24, 2012 #4 Most 7770s probably come with a dvi-vga adapter.... Upvote 0 Downvote
simmons33 Honorable Nov 7, 2012 699 0 11,160 Dec 24, 2012 #5 Most come with the Adapter. If it doesnt for some odd reason, Radioshack a DVI-VGA Adapter. Or get a Monitor at 1600x900 , 1680x1050 or 1920x1080 Upvote 0 Downvote
D donnyberger23 Honorable Dec 13, 2012 43 0 10,530 Dec 24, 2012 #6 My monitor does have 1600x900. If i buy this adapter, i still need to buy a dvi cable? Upvote 0 Downvote
Sunius Splendid Dec 19, 2010 9,582 0 31,960 Dec 25, 2012 #7 No. You plug the adapter to the graphics card, and the connect the adapter to the monitor with a VGA cable. Upvote 0 Downvote
