G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
i try to install the fax
using the way
start->settings->control panel -> addremove programs -> add remove windows
component...
but appears amessage with an error "0x2" in line 2088999411 ...
and the procedure stops....
can i install the fax directly from the windows cd???
tnks
using the way
component...
tnks
