Problems installing Nvidia GeForce GTX 660 Ti Drivers
ThisisPatrickN
5
Hi all,
Thanks in advance for any answers you may have.
I recently built a new PC from scratch. M friend and I built it, and everything went well.
I installed Windows 7 64-bit and the motherboard drivers and all wen well.
Then I attempted to install the GPU drivers for the card listed above. After installing them, and restarting my PC, Windows stops on the "Windows is Starting" screen. It's really frustrating, as I need this PC for 3D work.
I have some theories as to why this is.
Is it a GPU error (broken on delivery) or is the Motherboard (listed below) incompatible with the card. I am pretty certain, everything was built properly, but that may the reason.
Thanks for any help (specs listed below)
- Patrick
Specs
- Intel i7 4770k
-Nvidia Geforce GTX 660 Ti
-Gigabyte Z87-HD3 (Socket LGA 1150)
- Corsair 600w PSU
-16gb RAM
Booting up works fine without the graphics card drivers installed, if that's what you mean. I'm pretty sure if I removed the graphics card as well, it would boot up as well.
