Problems to share a hp deskjet 3535 and WinXP
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
Hi,
I'm trying to share a HP Deskjet 3535 from my WinXP. I
can print normally from my machine, but others machines
can't. These machines are finding and printing using my
share, but only blank pages are printed. An important
info: other users in my network that have administrative
privileges are printing without problems (pages are
printed normally, the blank pages are printed only
for 'normal users').
Any help?
Thanks.
Did you install it using Bruce Sanderson's instructions:
http://members.shaw.ca/bsanders/NetPrinterAllUsers.htm
Cari (MS-MVP) Windows Client - Printing/Imaging and Hardware
www.coribright.com
"Baccarin" <pekus@REMOVEpekus.com.br> wrote in message
news:12b401c4f328$028ef060$a501280a@phx.gbl...
> Hi,
> Any help?
> Thanks.
Make sure the Normal users have write access to the spool directory on the
sharing computer. The default is \windows\system32\spool\printers. I have
seen this when one changes permissions in system32 and propagates these
privileges to child directories.
Normally you will get a rendering error Event 45 in the system event log
when the graphic subsystem attempts to playback the EMF file.
Alan Morris
Windows Printing Team
Search the Microsoft Knowledge Base here:
;kbhowto]http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto
This posting is provided "AS IS" with no warranties, and confers no rights.
"Cari (MS-MVP)" <Newsgroups1@coribright.com> wrote in message
news:ev0ksA28EHA.2112@TK2MSFTNGP14.phx.gbl...
> www.coribright.com
> > Hi,
> > Any help?
> > Thanks.
Hi Carl and Alan,
I will try your tips tomorrow.
Thanks,
Alexandre.
Alan,
I changed user rights in this folder but it didn't work
too. Any other idea?
Regards,
Baccarin.
>-----Original Message-----
propagates these
system event log
file.
>Alan Morris
[ln];kbhowto
confers no rights.
message
instructions:
Hardware
>> www.coribright.com
>> > Hi,
I
machines
my
administrative
>> > Any help?
>> > Thanks.
Hi,
I get to print for the other machines from our network. I
needed to insert the color cartridge in the HP Deskjet
3535, and change Print Assistant to work only with the
black one. After configuring I could remove the color
cartridge without problems, and the remote machines
printed correctly.
Regards,
Baccarin.
