G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Hi all
Firstly, apologies if this has been asked a thousand times before, I did a
quick search but couldn't find anything.
My bruv has just bought a new PC and wanted to hook it up to his tv, he's
got an OEM ATI Radeon 9200 (one with no fan, just heatsink). Now although
I'm pretty good with most hardware, I've never actually hooked up a pc to a
tv before, so I told him hat he'd need and he went and got it.
This is where the problems began, on the back of the vid card there is an
svhs socket, I assumed that plugging in a svhs lead and hooking the other
end to the tv would work fine, however it hasn't. after hooking up all the
cables, and making sure the tv was set to the right AV channel, I switched
on the PC... but no matter what I try, I can't get it to recognise that
there is another display connected.
Now this has frustrated me for a while, there is a svhs to composite adaptor
that came with the PC, does this eman that the only way to hook it up is via
this and a normal video composite lead? I had hoped you could use an svhs
lead because of the better picture quality.
Also, do you have to adjust the desktop resolution or can you set the
resolution for the TV display seperately?
Thanks for any advice you can give.
H
Hi all
H
