Hello, I have a i7-6700k and a Corsair H60 AIO Cooler, I upgraded recently from an i5-6600k. The 6600k ran at around 40-50c in all games under load with the H60, but now with the i7-6700k I run at 65+c constantly in games not even under load. under load highest I've seen is 76c and the temps jump around like crazy they can go from 40c to high 60s out of nowhere and then back to 50s etc etc it just jumps around A LOT. Not sure what's causing it, if the cooler isn't strong enough to cool it. or if I didn't win the Silicone lottery? but I feel it should not be sitting at 70c under load on little <language edit> games like CS GO. Also, The Pump plugin was plugged into the spot W Pump on my Motherboard, and it didn't show me the RPM's of the pump so I switched it to Cha4, and now its showing it at 3k+ RPM so Not sure if it wasn't even on then or not. but even now that is shows it seems even hotter or about the same as before....
Moderator Edit: Please watch the language
