So I may have made a noob mistake. I built a rig using a Coolmax CUL850B PSU. I got it bundled with a bunch of other components through Portatech.com. Since getting it, I've run into some issues. If, and I say IF it powers on the computer, it will run just fine without issue. The moment I shut the system down, the light on my motherboard goes off, and it will not power back on. I have to fiddle with it, unplug cords, unplug from the wall, switch it on and then off again. I went through everything I possibly could to ensure there is nothing grounding out, all the way to insulating the board from the case. I also had the issue when I breadboarded the setup, outside the case. It did it to me again tonight, and now the power switch seems to be stuck in the on position, and will not set in the off position. I still have time to return/exchange it, but wanted some input first.
