**Problems with G1 GTX 980 ti 6gb**
OGGamer
Hello,bought my new pc 2 days ago,im having problems with my gpu
but first take a look on my specs
cpu=i7 6700k (skylake)
mobo-asus maximus viii hero
ram=16gb g.skill ripjaws DDR4
psu=EVGA SUPERNOVA 850 G2
case:corsair graphite 780T
cpu cooler-coolermaster nepton 240m
OK lets start
I think something is wrong with my GPU
without gaming or anything,just surfing on web im having high temps and clocks
right now i just have my chrome open and as i see on OC GURU 2 settings are ---->GPU=925MHZ
memory=7010 mhz
voltage 1.012
and im having 58 Celsius (°C) and fans are not spinning
can someone please help me out asap
thank you for youre time
well i dont think so,because others have their gpu having 200mhz and idle with fans not spinning 35-40 Celsius (°C)
and im having mine one running 1000+mhz when im not even gaming,and im having 60 Celsius (°C) with fans not spinning
MSI introduced a feature back in 2008 whereby the fans shut off when they are not needed. Asus added the feature last year with the 970. Not sure about the G1. But if your card is equipped with this feature, the behavior you are observing is perfectly normal.
58C is not considered hot.
http://www.guru3d.com/articles_pages/gigabyte_geforce_gtx_980_ti_g1_gaming_soc_review,9.html
Tests are usually performed at idle (35C) and max load (69) ... latter oft using Furmark. Testing under other conditions is hard to draw conclusions from as the intensity of the load can not be quantified.
