Problems with HP 7260 Photosmart printer
David
2,039
Archived from groups: microsoft.public.windowsxp.print_fax,microsoft.public.windowsxp.photos (More info?)
Hiya anyone come across this before please,
Under XP Pro SP2 if I try to install the latest (indeed any) HP printer
drivers for my 7260 printer I get the blue screen of death when if comes to
finalising and accepting the printer as my default or not. This is
with/without any non-Microsoft services or start-up programs running.
Went I do finally get the driver working if I then switch the printer off or
disconnect the USB while the computer is on I get the Blue screen of death
which performs a memory dump to "save my hardware from possible damage"!!.
Connect the printer via the front USB port (intended for camera connection)
and installation of the driver could not be easier, installed without any
problems and I can turn the printer on and off with the computer
running. only problem (if it is one!) is that the part of the driver program
which shows estimated amount
of ink left in the cartridges does not work.
Anyone else come across this problem with HP drivers and found a solution
please.
TIA
DaViD
I like pigs. Dogs look up to us. Cats look down on us. Pigs treat us as
equals. - Winston Churchill
http://tinyurl.com/7yw4m
Look for help with your printer.
Paul Ballou
MVP Office
http://office.microsoft.com/clipart/default.aspx
http://office.microsoft.com/templates
http://office.microsoft.com/home
Control the things you can and Don't Worry about the things you can't
control.
"DaViD" <dbedford@dsl.pipex.com> wrote in message
news:416abb9b$0$3935$cc9e4d1f@news-text.dial.pipex.com...
> to finalising and accepting the printer as my default or not. This is
> or disconnect the USB while the computer is on I get the Blue screen of
> death which performs a memory dump to "save my hardware from possible
> damage"!!.
> connection) and installation of the driver could not be easier, installed
> without any problems and I can turn the printer on and off with the
> computer
> program which shows estimated amount
> please.
> TIA
> DaViD
Sorry Paul but been there and done that,also discuss with HP
"Ex perts" and they have not answers.
Thanks anyway
DaViD
>> printer drivers for my 7260 printer I get the blue screen of death
>> when if comes to finalising and accepting the printer as my default
>> or not. This is with/without any non-Microsoft services or start-up
>> programs running. Went I do finally get the driver working if I then
>> switch the
>> printer off or disconnect the USB while the computer is on I get the
>> Blue screen of death which performs a memory dump to "save my
>> installed without any problems and I can turn the printer on and off
>> with the computer
>> solution please.
>> TIA
>> DaViD
>> as equals. - Winston Churchill
Thanks anyway
DaViD
>> switch the
>> with the computer
>> solution please.
>> TIA
>> DaViD
Archived from groups: microsoft.public.windowsxp.photos,microsoft.public.windowsxp.print_fax (More info?)
DaVID
Did this happen also under SP1,
Might have to try a new USB cable too.
I have the same printer and have not had a problem under either SP1 or SP2
When I bought mine the clerk at CompUSA said good luck....they have had a
lot of them returned.....
I also noticed a few updates on the HP site for this printer if you havent
tried those already.
> please.
> TIA
> DaViD
Thanks, but tried that and other USB port. Guess I need to buy another
brand printer.
riduv86 wrote:
> DaVID
> or SP2 When I bought mine the clerk at CompUSA said good luck....they
> have had a lot of them returned.....
> havent tried those already.
>> programs running.
>> with the computer
>> solution please.
>> TIA
>> DaViD
