Question Problems with M.2 SSD in USB enclosure ?
HasseM
I have got a Samsung 970 EVO NVMe M.2 1TB SSD that I have placed in an USB3 Enclosure as the ultimate portable drive. However I experience lot's of problems. Especially during longer operations (eg making a backup) and even more during write operations. Suddenly the drive is not recognized anymore by Windows 11. The drive is only slightly warm. I tried 2 other enclosures (all chinese brand but also very different) and experience the same kind of problems. It's very frustrating.
I need some more insights in this matter as ordering one more enclosure does not seem very sensible from here on. So I was wondering if people have similar experience with M.2 NVMe drives in USB3 enclosures? Both positive (tell me the brands you use) and negative.
Did you install thermal pad properly?
Orico-M2-Ssd-Behuizing-Nvme-10Gbps-Pcie-Ssd-Doos-Voor-M-2-Nvme-Ngff-Sata-Ssd.jpg_.webp
I have got a Samsung 970 EVO NVMe.M2 drive of 1TB that I have places in an USB3 Enclosure as the ultimate portable drive. However I experience lot's of problems. Especially during longer operations (eg making a backup) and even more during write operations. Suddenly the drive is not recognized anymore bij Windows11. The drive is only slightly warm. I tried 2 other enclosures (all chinese brand but also very different) and experience the same kind of problems. It's very frustrating.
I need some more insights in this matter as ordering one more enclosure does not seem very obvious from here on. So I was wondering if people have similar experience with NMVe drives in USB3 enclosures? Both positive (tell me the brands you use) and negative.
Normally for enclosures at that 10Gbps speed I use the Sabrent EC-SNVE which performs well and has never caused me a problem. For faster speeds at 20Gbps I use the Orico M2PAC3-G20 which is obviously more expensive since its higher speed. My Samsung 970 EVO Plus 1TB is installed in that and performs flawlessly.
Test the ssd in a pc m.2 slot.
USB3 is not all that fast, hard to see where it'd tend to overheat at 800-1000 MB/sec transfers...
Maybe it's one of the 970's from last year with firmware issues/data corruption, etc? (Check for firmware updates in Samsung Magician, but in an M.2 NVME slot, not in a potentially problematic enclosure?)
My personal feeling is that it is the controller chip overheating from poor chinese design skills. As @mdd1963 says, USB3 isn't fast enough to overheat the drive and it just isn't hot at all only slightly warm.
It's good to know that @dwd999 has a positive experience with the same manufacturer but at a higher rated speed (which USB3 never reaches) and this attributes to my chinese controller hypothesis.
@Bob.B installing it in my system is not an easy job as I have a custom waterloop with cooling even over the NVME's, VRM's and even on the active backplate of my RTX. So for me to go in that direction I need more reasons to believe it is a failing drive.
@mdd1963 It is actually a replacement for a failing 970's from last year.... lost a big amount of data because of it. My system now runs a 2TB 980 and the replacement is now an external drive as an ultimate, easy to carry, external drive.
So what's next from here on? Hopefully people can share more positive / negative results and maybe we can find a common cause?
I opened up my Orico 10GB/s and it has a RTL9210B controller inside and I also opened up my other one (see links above) and this one also contains a RTL9210B controller. So 2 out of 2 failing is a RTL9210B controller.
Hopefully people are interested enough to share their experiences and controller type.
Edit: It seems to be more complicated then just the controller brand/model. There is a long read here about but already most info is a few years old but many problems are similar.
meanwhile I found out that I have another enclosure laying around in a box:
https://nl.aliexpress.com/item/1005001809792729.html?channel=twinner
It has a RTL9210 controller (without the B).
What would be a good way to test it? Problems only arise after longer transfer sessions (eg 100GB+). I would like to keep the data that is already on it. (I do have a backup, but it took me a very long time to get everything on it that I wanted to be on it, without errors).
Transfer speed is controller dependent which is why I use the higher 20Gbps Orico model even though its more expensive. That Orico M2PAC3-G20 model uses an Asmedia 2364 controller which is designed for speeds up to 20Gbps. It helps that I have 2 USB Gen 3.2x2 20Gbps ports on my motherboard (1 back panel and 1 connector for case front panel). With those I get transfer speeds of 1.2 GB/s from computer to Orico usb drive with Samsung 970 Evo Plus m.2 inside and 1.8 GB/s from usb drive to computer where the internal receiving drive is faster. The Samsung m.2 in the Orico case maxes out at 72 degrees C during 100GB transfers but there is no reduction in speed and transfer speed is consistent.
You will need to figure out how your going to approach this based on the parts/tools and what you have access to.
Check the power plan/selective suspend and disable it.
Check device manager/usb hubs/properties and turn off the power option.
Use crystal disk mark and run a couple of passes see if that makes the problem happen.
So I disassembled the Sabrent EC-SNVE case and saw that it has the same 10Gbps Realtek RTL 9210B chip as your other drives. I transferred a 50GB file and got 780MB/s onto the drive and 980MB/s off of the drive going into the Gen3.2x2 port on my computer. I even use one of these cases for the 2TB m.2 hooked up to my Samsung TV and it runs for hours without any problems. So this may be an Orico-only problem which surprises me considering how well their 20Gbps model performs.
