Problems with my build
DoctorFrantic
6
I have a problem with my own build PC. I have rebuild my PC in a different case (Inter-Tech W III RGB) and it feels like my components aren't getting any power at all. I have replugged the cables and still no luck. I earthed myself and made sure there is no metal-on-metal with the components, so no short circuit going on somewhere.
My specs are:
MSI B85-G43 Gaming
MSI Radeon 560 R9 4GB
Intel i5 4460K
CoolerMaster Masterliquid
8GB RAM
450 watt PSU
Hopefully this gets resolved before I let someone come over for it
I am going to refer you to our general troubleshooting thred:
http://www.tomshardware.com/forum/261145-31-perform-steps-posting-post-boot-video-problems
Work through the list. WORK!, not just read!
If you still have...
If you still have issues, come back here with the results of EACH step in the list, and we will try to help.
Since we can neither see nor touch your PC, the individual results of each step allow us to eliminate possible problems and common errors.
Help us to help you!
Try and go for at least an 80+ Bronze certified or higher. You don't want to go cheap on PSUs you risk frying your computer.
http://www.tomshardware.com/forum/261145-31-perform-ste...
The problem was the standoffs and a PSU that was too weak to run all fans at once so I found the problem and know what to upgrade next, thanks a lot!!
It's a Corsair V450, but it wasn't too bad
