Problems with my PC's cooling
DeathAngell
Commendable
Oct 8, 2016
51
I have been having issues with the cooling in my computer for a while. The GPU hits around 60 idle and is hot to the touch inside my case. CPU seems to be alright but even the inside of my case seems hot. I have 2 intakes on the front, 2 exhausts on the top and 1 on the back.
How do I fix this??
So what do I do with that?
Hi
I am new to this forum but not your problem - personal experience over 18 years.
I would suspect you have been hijacked - possible rootkit.
I would suggest you get the 'experts' to help - go here first -
https://www.whatthetech.com/hijackthis/
Do read the instructions - do all your inhouse scans, reboot, then download hijack this and save to your desktop.
Before installing I would suggest you work 'OFF LINE'. You could stay with this link for help bit I have found the below as good if not better.
After installing HJT, do the scans as suggested, reboot and save to a folder in the desktop for easy access.
Then go here for your expert help - after you register go here -
http://www.spywarewarrior.com/viewtopic.php?t=32672
Again, do read as it will assist your helper and indicate you are prepared.
Then go here and select the right Forum - select Help with Spyware Removal
http://spywarewarrior.com/viewforum.php?f=5
Explain your problem with as much detail as possible and what you have used to scan. Then post the logs from HJT instructions. Dont worry if you do not get an immediate response.
Let me know if links work OK. I would strongly suggest you do not go to any links via any search engine that offers help to remove anything. Be patient, respond promptly, bumpers get ignored, and carry out all instructions to the letter. If something does not work, stop and contact helper with the problem.
Good luck
Dick
Still not linking to the right place...
I have popups disabled.
