Question Problems with tpm in bios
Feb 24, 2025
So when I turn on tpm 2.0 in my bios and I click save and reset and I go back into bios it says disabled but I didn’t disable it, it just did it by its owns can somebody help me by fixing this issue
Secure boot and TPM 2.0 generally need to be enabled BEFORE you install Windows, otherwise you may end up with no video output or refusing to accept the settings change. Also, you generally need to have CSM disabled first. What Windows version are you intending to use?
I’m using windows 11 I’m really trying to slice this issue because I want to play valorant
