Problems with Windows Audio Graph Isolation Process
staebles
33
Since two days ago, my Windows Audio Device Isolation process has been consuming more than it should. It stutters whenever any audio is play once every 2-4 seconds. Even system alert sounds stutter.
The only change I made recently was the new Windows 10 updates, but I uninstalled them with the same problem. I update my Realtek Driver, updated my ATI drivers - even went in and disabled each driver in my Sound section of the DevManager, still not fixed or isolated.
Does anyone know what I can do? And yes I have the audio enhancements disabled from CPanel.
System Information
Time of this report: 12/12/2016, 23:02:08
Machine name: DESKTOP-QIHB4QA
Machine Id: {2D1DB719-C711-4701-A88A-8231705026CD}
Operating System: Windows 10 Home 64-bit (10.0, Build 14393) (14393.rs1_release.160715-1616)
Language: English (Regional Setting: English)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: To be filled by O.E.M.
BIOS: F2
Processor: AMD FX(tm)-8320 Eight-Core Processor (8 CPUs), ~3.5GHz
Memory: 16384MB RAM
Available OS Memory: 16350MB RAM
Page File: 3740MB used, 15041MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.14393.0000 64bit Unicode
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0900&SUBSYS_1458A056&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.8004 (English)
Driver Attributes: Final Retail
WHQL Logo'd: n/a
Date and Size: 11/29/2016 12:00:00 AM, 5523456 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Headset Earphone (HyperX 7.1 Audio)
Default Sound Playback: No
Default Voice Playback: Yes
Hardware ID: USB\VID_0951&PID_16A4&REV_0003&MI_00
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: USBAUDIO.sys
Driver Version: 10.00.14393.0000 (English)
WHQL Logo'd: n/a
Date and Size: 7/15/2016 12:00:00 AM, 132096 bytes
Other Files:
Driver Provider: Microsoft
Cap Flags: 0x0
HW Memory: 0
Description: Realtek Digital Output (Realtek High Definition Audio)
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Description: Realtek Digital Output(Optical) (Realtek High Definition Audio)
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Sound Capture Devices
Description: Headset Microphone (HyperX 7.1 Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Date and Size: 7/16/2016 06:41:52, 132096 bytes
Cap Flags: 0x0
Format Flags: 0x0
This shows what it does and how to fix it: http://www.howtogeek.com/273764/what-is-windows-audio-device-graph-isolation-and-why-is-it-running-on-my-pc/
See if this helps, it might not but its one problem the last patch created, and I have seen it effect other operations of windows as well: http://www.tomshardware.com/faq/id-3267507/fix-100-disc-usage-system-service.html
this might help too: right click start button
choose command prompt (admin)
type SFC /scannow and press enter
this scans system files and may fix this behaviour
seems there have been some changes to how windows handles audio: https://msdn.microsoft.com/en-us/windows/hardware/drivers/audio/low-latency-audio?f=255&MSPPError=-2147217396
