Project CARS 2 Performance Review
Question on the Minimum/Recommended specs:
Configuration
Recommended
<snip>
Graphics
GeForce GTX 1080 or Radeon RX 480
I'm assuming the "GTX 1080" is a misprint. While I'm an AMD fan, I know the RX 580 isn't anywhere near as good as the GTX 1080. Also, I didn't see any testing done with the GTX 1080, but the GTX 1060 did show up.
Also...any plans to do some more testing with other older/lower GPUs? I'm only asking because a) although the listed minimum (GTX 680) isn't too far off the RX 580/GTX 1060 in performance, it is 3 generations behind (& you did testing with GPUs that are technically lower on the hierarchy than a GTX 680); & b) my own GPU (R9 380) is roughly comparable to the 680 (& superior to the GTX 1050/1050TI & RX 460/560 that were used in testing).
I want to try to understand why my old i-7 950(overclocked to 4GHz from 3.06 stock)with a great aftermarket air cooler supposedly couldn't run this game(says minimum i5 3470). I have it paired with a Zotac GTX 970 and 12 GB's of DDR3 1600Mhz RAM so shouldn't that be enough to run the game with good FPS at 1920x1080P resolution?
try it and u will see if it will be enough
but stock i7 950 has around half single core performance of i7 3450...
so dont expect miracles
Any hope of doing VR performance? Like with using Nvidias FCAT tool, or by measuring reprojection times, etc.?
VR sim racing is a real big deal, and PCars 2 is one of the best looking but most demanding of them. It would be nice to have a list of the most important graphics settings with respect to performance impact.
Shortly after the release of Project CARS (Community Assisted Racing Simulator), Slightly Mad Studios and World of Mass Development started fundraising for its sequel.
They didn't make enough profit on the first?
