Question Project Menu Settings *please help*
Dec 15, 2022
5
I somehow (i don't have a clue) have the windows 8 project menu setting on windows 10. When you press WIN+P it comes up the windows 8 project menu instead of the windows 10 project menu. I absolutely hate the windows 8 version and need the windows 10 version back. How can I revert or get the normal one back?
that windows 10.
No, you totally missed my point here. You see the red menu? On the right hand side of the monitor? That is the windows 8 layout. Usually windows 10 is more elegant, wider and transparent. I want that menu back. I am also on windows 10 so it only makes sense I use the windows 10 one.
