Hello community, I hope you are all doing well.
I'm having an issue with my PS4 or with the PS4 controllers, I'm not sure. My controllers started running out of battery, and when I tried to charge them, I realized that they wouldn't charge. The orange light simply doesn't appear, and even when I try to use them connected with a USB cable to the PS4, they don't turn on. They only light up for about a second, which is the short amount of time I can use them, and then they turn off again.
It seems very strange to me that it could be a battery or charging port issue, especially since both controllers stopped working at the same time. Here's a list of things I have already tried:
Even when I try to connect either of the two controllers to my PC, they are not recognized as devices.
Does anyone know what the problem could be? Thank you very much.
- I have already tried resetting them with the Reset button.
- I have already tried changing the USB cable, and all those cables work with other devices.
- I have already tried changing the USB port, and all those ports work with other devices.
- I have already tried updating the PS4, and it was already up to date with the latest version.
- I have already tried using the PS4 in safe mode, but when it turns on, it doesn't allow me to proceed because it asks me to turn on the controller with the PS button, which only stays on for a second as I mentioned before.
- I have already tried using a power transformer to connect it differently.
