Psp wireless connection
kornhed101
Hello,
I cannot get my psp's to connect through my Netgear wireless than gains internet from an AT&T modem. Both worked just fine with my former internet provider. Please help!!
I've had the problem before too. The PSP is incompatible with some wireless security options. You will have to change your wireless security settings on the router/modem itself. Change the security setting to something the PSP is compatible with. Hope this helps! :sol:
