PSU Doubt for i76700 with Asus H170 Pro Motherboard
danielpc
21
i7 6700 not K version
Asus H170 Pro
(old Atx 5670 GPU DDR3 1GB)
this above configure is planned to upgrade my old pc to new but i have some doubts about the power supply, how much power requirement needed to this configuration i have 450w, 400w zebronics smps.
is this enough to this processor ? or planned to buy "Antec BP450PS 450 Watt SMPS" is this enough to this configure.
please help
Thanks.
wattage wise you are probably ok.... power supply quality... meh, not so good. but that is probably beside the point here. you will need a power supply that is skylake approved(haswell approved likely is good too). the reason being is the power supply needs to be stable at ultra low voltage calls when skylake goes into its lowest power states(idle/sleep). your old power supply probably wont work for you.
http://techreport.com/review/24897/the-big-haswell-psu-compatibility-list
true 400W ...
can you recommend any one psu for me please ...
i search a lot yesterday finally i got some models for my need this is enough to my budget
thanks nikoli707 for [Hasewell Compatibility] link...
Cooler Master Thunder 450W [Hasewell Compatibility]
Flipkart Link
Antec VP450P [Hasewell Compatibility: "has not been confirmed yet" ]
Flipkart Link ]
Corsair VS450 [Hasewell Compatibility: "likely compatible" but "currently validating" ]
Flipkart Link
which one is best and can you suggest any one of these models
Thanks
http://techreport.com/review/24897/the-big-haswell-psu-...
Thanks ....
Flipkart Link
Flipkart Link ]
Flipkart Link
i selected these 4 models are enough to my budget but i duno which one is best can you help me please
Thanks
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371045
the antec vp450 is haswell compatible. that link i sent you was more informative about how modern cpu power states affect power supplies.
the built in igpu(intel hd 530) on the 6700k is going to be faster in every way than your old 5670, throw that in the trash lol. im just kidding, you can use it i guess if you need more outputs for more monitors, but otherwise its pretty much junk.
, throw that in the trash lol ...//// heheeh thanks.....
but i think Antec VP450 and Antec VP450P both are different or both are same model
extremely very thanks for your great helpful guides....
