Hallo! I would like to ask you "Should i place my power suply with the fan taking air from the inside of the case, or should it take the air from the bottom (out) so it doesnt affect the inside of the case?
*Consider that i Have two 120mm Fans at the top of my case pulling air inside.
*Consider that i have one 140mm Fan pulling air outside of the case. At the back of the case.
*And the GPUs fan also
Would the air pressure be fine? Thank's a lot!
