Psu for 7850 and 3570k
guilly
23
Hey,
Im just finishing my build and want to make sure i get an adequate psu.
Spec:
Asrock z77extreme3
I5 3570k
Asus 7850 2gb
8gb ram
Inwin buc 101
I will most likely want to do some mild overclocks to start and would like to future proof for xfire down the road. I havent purchased the case yet neither if anyone has any suggestions plz let me know.
Thanks!
For a system using a single reference design Radeon HD 7850 graphics card AMD specifies a minimum of a 500 Watt or greater power supply. The power supply should also have a combined +12 Volt continuous current rating of 27 Amps or greater and have at least one 6-pin PCI Express supplementary power connector.
For a system using two reference design Radeon HD 7850 graphics cards in 2-way CrossFireX mode AMD specifies a minimum of an 600 Watt or greater power supply. The power supply should also have a combined +12 Volt continuous current rating of 39 Amps or greater and have at least two 6-pin PCI Express supplementary power connectors.
This XFX 550W PRO550W Core Edition...
Hi - Where are you located and what's your budget?
I'll assume 2 hdd & 3 case fans, & stock cooler, but you might
want to add after mkt cooling if you are going to CF
COOLER MASTER HAF XM RC-922XM-KKN1 Black Mesh, Plastic, Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119257#top
Fractal Design Define R4 Black Pearl w/ USB 3.0 ATX Mid Tower Silent PC Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811352020&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3938566&SID=#top
Corsair Carbide Series 400R Graphite grey and black Steel / Plastic ATX Mid Tower Gaming Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139008
Antec Three Hundred Two Mid Tower Gaming Case 302 ATX 3X5.25 6X3.5INT No PS Front USB3.0 & Audio
http://pcpartpicker.com/mr/ncixus/antec-case-threehundredtwo
Thanks for the replies,
My budget was 80 cnd im from canada. I will take a look at those cases and concider i was leaning towards the inwin because of its price (99 cnd) and the good air flow plus usb 3.0.
Is 750w really necessarry? If i dont xfire right away? Can i get away with a 500w or am i pushing it?
A good 500w PSU would work now. But when you xfire you will have to spend more money.
It's cheaper to buy one PSU now, than have to end up paying for two.
+1 i would of answered your question the same.
This XFX 550W PRO550W Core Edition Single Rail ATX 12V 44A 24PIN ATX Power Supply 80PLUS Bronze meets the CrossFire requirements:
http://ncix.com/products/?sku=59615&vpn=P1550SXXB9&manufacture=XFX&promoid=1285
This one is a good deal after rebate XFX 750W PRO750W Core Edition Single Rail ATX 12V 62A 24PIN ATX Power Supply 80PLUS Bronze PSU:
http://ncix.com/products/?sku=59617&vpn=P1750SNLB9&manufacture=XFX&promoid=1285
