Hi, All!
I am trying to replace the blown out Newton (NPS-250EB A) PSU in my older Gateway 710XL computer. The original PSU was only 250Watts and I would like to increase that to at least 350-400Watts with the replacement, if I could. My questions for the forum are:
1) Can I go from a 250W to a 400-450W PSU in this computer? Or is there such a thing as too much power?
2) The Dynex 400W PSU I bought as a replacement does not have the P10 connector that the Newton had. Thus, I am short one connection on the motherboard. Would this cause the PSU not to fire up at all when I tested it after having connected all other cables?
3) Where can I get a PSU with the extra P10 cable? Hardly any of the PSU's I have found online have it.
4) If I can't get a PSU that fits my case with the P10 cable, is it possible to get an adapter of some sort to that I can plug into one of the unused SATA connectors on one side and plug the other end into the P10 slot on the motherboard? Would this cause any power/heat problems?
5) The old Newton has a fan bolted to the external top. None of the PSU's I've seen on the market today have this. Is this necessary for cooling or just an added bonus that Gateway installed? It sits right next to the heat sink and I suppose it used to do a good job of blowing cool air right over the sink. But can I get away without this arrangement now?
Sorry to be so full of questions but I'm more of a software guru. I don't usually work on hardware. But I couldn't see paying $150 to the local teenager to install a new PSU when it's just a matter of a few snap in plugs!
Thanks!
Thanks!
