psu for r9 280 (not 280x)
rina23
hi,
i'm on a budget and plan to upgrade my gpu..and i plan to get r9 280(non x).. i have a corsair cx500 (12v rail is 34) and i'm wondering if it is sufficient for the r9 280..i don't plan to overclock nor xfire..and also for my psu will it be better to get gtx 760
my specs:-
i5 4670k
asrock z87 pro 4
G.SKILL Sniper 8GB (2 x 4GB)
wd caviar blue 1 tb (will be getting 120gb ssd in the near future)
lg optical drive.
Depends. If you plan to overclock the graphics card, the R9 280 is better. Otherwise, at stock, the GTX 760 is better.
For the high-end nvidia cards, my top brands are as follows:
1. EVGA with ACX Cooler
2. Gigabyte Windforce
3. Asus DirectCU II
For the high-end AMD cards, my top brands are as follows:
1. Sapphire Vapor-X or Dual-X
3. Asus DirectCU II
The Asus one is decent. It may be the quietest card, but it's not as good in price/performance/temperature as the ones above it.
Official specs for R9 280 state the requirement of 25A and a 500W psu minimum. This would normally be no problem if your PSU was a quality one, but CX series is not something I would rely on for gaming due to cheap capacitors. Your best bet is XFX or Seasonic power supply. At least 500W would be just fine, but since you are buying new, why not get 650W and have some headroom. If you prefer Corsair, stay away from CX for anything but office work - get AX/HX/TX/RM series.
thanks guys for your quick answer..but the problem is my gpu is dying on me and i need a new gpu and as i'm on a budget i cannot afford to buy a new psu..when i bought my psu 2 years back i didn't know that it was not a decent psu :-( but as i;m on a budget i'm stuck with it..and also in your opinion gtx 760 or r9 280 will be better..
thanks..if i'm going with my current build then 760 it is..
and btw is the seasonic eco series a good psu..i might be able to fit the Seasonic ECO 600 or Seasonic S12II 520 Watts into my tight budget..
I think the ECO has two 6-pin. I know the S12II has one 6-pin and one (6+2)-pin. The GTX 760 requires two 6-pin so either PSU will work. The R9 280 (or R9 280X) requires one 6-pin and one 8-pin so only the S12II will support it. You can still use the ECO to run the R9 280, but you'll need a molex to PCIe adapter, which is not as convenient.
3. Asus DirectCU II
3. Asus DirectCU II
ok..thank you very much..i really appreciate your help..as i don't plan to overclock my card i think i'll get the 760..and also i want a quiet card i think i'll get the asus..
