psu hold up time >16ms vs hold up time >17 ms Input and Voltage 90-264Vac (Full Range) vs Input Voltage 90-264Vac (Auto Range)
Ripple is probable pretty much the same, but with time it will increase (as capacitors age). Pro is better, because ripple will increase much less then with non-Pro version.
But if you really want a PSU that will last you 30 years, that will heat up very little, and have a very little ripple, buy something like this (resonant PSU):
http://www.corsair.com/en/power-supply-units/hx-series?power=650%20Watts|
The pro is better. Ripple is basically little dips in the output voltage.
These dips can be either at the AC input frequency (50-60hz) or at the PSU's switching frequency (10s of KHz)
Beside additional wear on the other computer components, ripple can cause instability and crashes.
I can't tell you that without a brand and model of the input and especially output electrolytic capacitors used in both PSUs.
Pro should last over 10.000 hours at 105 oC. For every 10 oC decrease in temperature, lifespan doubles.
This is based on one capacitor that I was able to find out the brand, model and specs.
