Hello! Yesterday I have upgraded the CPU, RAM and motherboard of my PC. For some reason the GPU is not working. No signal on the display and the GPU fans are not spinning. Everything else seems to be working fine. I have connected some USB speakers and couldn't hear any beeps. I have double-checked all the connections and they seem to be fine. I am thinking that the reason the GPU isn't working is that the PSU isn't supplying enough power.
Specs:
Asus TUF x470-Plus Gaming
AMD Ryzen 5 2600
Gigabyte GTX 1050
Corsair Vengeance LPX 16GB 3000Mhz Dual-channel
A SSD, an HDD, and a CD-ROM
Unbranded 450W PSU
The PC should use a maximum of around 350W, which the 450W PSU should have no trouble providing, although I cannot think of any other issue.
Edit: Would the PC always restart if it didn't POST successfully? Because mine never restarts.
Edit: Previously the BIOS would appear on display 1. With the new motherboard, it appears on display 2. Since I thought it would still appear on dislpay 1, I turned display 2 off. So the BIOS appears on display 2, then display 2 no longer has signal and Windows appears on display 1.
Specs:
AMD Ryzen 5 2600
Gigabyte GTX 1050
Unbranded 450W PSU
