Well after a long research I have come up with 2 options for the system upgrade at this moment, they are as follow-
Note- I have increased my budget for a GTX 970 coz it seems to be a greater value for money rather than a GTX 960 4gig. So the GPU upgrade is fixed.
Now the 2 upgrade with the GPU,
1. CPU Cooler- Since my old CPU cooler has accumulated some dust on it was thinking to change it with a AIO liquid cooler from Cooler master. Although I am facing no issues with my current cpu cooler.
2. PSU- Another thing is the PSU I have a 6 yr old Cooler Master 500W PSU, which is lacking a 8 pin pcie connector for gpu, and is ageing. So a PSU upgrade is also an option. Which one to get if I get a GTX 970
So my question is which one should I go for GPU with PSU upgrade and hold the CPU cooler for next to next month OR should I go for GTX 960 which only needs a 6-pin connector which my old PSU has and, get a Liquid cpu cooler?
Thus GPU with PSU OR Less powerful GPU with CPU Cooler?
Please hep, any feedback will be appreciated
