Hello guys, newbie here. I bought a entry-level prebuilt gaming computer, for which i will be using an entry-level GPU. I need help determining whether my power supply is good enough, or if it's going to risk my computer it's life:
Firstly, I wanna say I wont be overclocking anything (per se, i wont OC them myself. ie factory OCs)
My PSU stickers says this:
input 100-240 ~8A 50-60Hz
output max power 460W
+12VA 18A
+12VB 16A
+12VC 8A
+5V 25A
+3.3V 17A
-12V 0.3A
+5 Vaux 2A
Max comb. power on 5V and 3.3V is 142W
Max comb. power on 12VA-C is 385W
Now, having read some of the stickies, i have determined that it is probably a multirail thingymajig (confirm?) because of the A B C 12Vs. But i am not sure if i can still handle the GPUs in tier (row) 7 of the hierarchy chart (http://www.tomshardware.com/reviews/gaming-performance-radeon-geforce,3018-7.html) [If needed, let's use the GTX 550 Ti and Radeon HD 6770 as reference.]
Additionally, i know for SURE it doesn't have a 8 pin connector. only 2 6-pin connectors. Which is where the 2nd confusion arises.
See Images Attached. Are these considered the 2x6pin connectors that some cards require? Because if it is, doesn't that mean the power still comes from a single 12V source? Or is that supposed to be like that? Also, If i am using a GPU card that only requires 1 6 pin connector, which one do i connect it to, the one that's closer to the PSU (middle) or the one that's at the end of the wire?
Summary:
1. Is that a multirail?
2. Can it support tier (row) 7 cards in the hierarchy?
3. Are those the correct 2x6 pins?
4. Which pin should I use for a 1x6 pin card?
Thank you for taking the time to read, understand and post.
Basically the wire is like this: PSU ------ 6 pin ------ 6 pin
+12VA 18A
+12VB 16A
+12VC 8A
+5V 25A
+3.3V 17A
-12V 0.3A
+5 Vaux 2A
Summary:
