T taha488jsr Jun 10, 2018 1 0 10 Jun 10, 2018 #1 I have asrock h91 m plus mobo and planning to go for gtx 1050ti windforce oc 4gb which SMPS should I use?
rocktalkrock Judicious Jul 4, 2017 6,077 280 36,640 Jun 10, 2018 #2 You don't need much power for that setup. The EVGA 500 B1 is often recommended for a low power build. Upvote 0 Downvote
PuperHacker Honorable Jun 25, 2016 993 12 11,715 Jun 10, 2018 #3 That depends on the rest of the system. If your CPU is about 100w TDP, a https://pcpartpicker.com/product/dDH48d/corsair-txm-gold-550w-80-gold-certified-semi-modular-atx-power-supply-cp-9020133-na would be able to do a good job, leaving you space to upgrade. If you need a cheaper solution, this: https://pcpartpicker.com/product/TgW9TW/seasonic-power-supply-m12ii520bronze would be quite a potent PSU. Upvote 0 Downvote
R Rexper Respectable BANNED Apr 12, 2017 2,132 2 2,510 Jun 11, 2018 #4 The S12ii and EVGA B1 are both mediocre, usually overpriced PSUs. You would be fine on a good 400w PSU. Look for a Be Quiet Pure Power 10 400w+ or Corsair CX/CXM grey. Upvote 0 Downvote
