Question PSU recommendation for my build
jonystar
7
I have bought a new computer:
CPU: i5 12400
MB: GIGABYTE B660M DS3H DDR4
RAM: 32 GB
SSDs and PSU i used from the old computer but unfortunately PSU from my old computer died and now i need a new one. At the moment i am using Gigabyte P850GM 80 PLUS GOLD that i got from a friend who just went on a business trip and will want it back when he arives home, next friday. What i want for new PSU to have:
  • Zero RPM or for fan to start after it reaches certain % of load, like the one i am using now.
  • Modular
  • Flat cables
  • budget max 100€
Thank you for the help.
so a 650w is gonna be more then enough especially since you want a full modular one (since you want modular and flat etc.. because a 500w is more then enough but you want find same specs )
there for i suggest you the RM650x gold modular stable
and with possibility yo add a gpu if you needed one one day
well @jonystar they are good but not the best and compared to what other's are giving for price + performence
asus is too costy
take a look at ldlc the french reseller in euro 155 while you get
Corsair RM850x 80PLUS Gold for 10 euro more
and is much better
even finding it at a low price there's still much better the corsair 650w gold is fair better with more watt
