[SOLVED] PSU Recommendation For Ryzen 2700X+RX 580
Rit101
Commendable
Jul 30, 2020
18
I builded my pc 5 months ago. Having an issue from start. Randomly my Monitor(It says no signal), Keyboard and Mouse stops working while everything else like cpu fan, gpu fan is running. This happens 1-2 times every 1-2 days. I don't know what causing this issue but i think kinda my 550 watt psu is faulty or not giving enough power to my rx580. So, please recommend me how much watt PSU needed for my system to run without any power issue?
Here are my PC Specs -
Ryzen 7 2700X
ASRock X570 Phantom Gaming X
Sapphire RX 580 OC Lite 8GB
Crucial Ballistix 3000MHz (2x8GB)
Antec VP550P Plus 80 Plus certification(550Watt)
Here is the issue - View: https://imgur.com/a/Qy6NV6d
That Antec is not a good psu. It's has double forward with groupregulation which has bas voltage regulation for modern hardware.
Can you please tell what causing my monitor, keyboard and mouse to stop working occasionally!
Can be the psu, motherboard, bad videocable, old MB bios etc.
On what speed is your ram set in MB bios?
I use RAM at 3000MHz with xmp profile. Without xmp it remains at 2666MHz by default though company sell thia ram with 3000MHz tag.
