shrapnel_indie :
I do agree that neutral (white) and hot/live (black) wires get reversed quite often enough that it could be a problem. It's why decent outlet testers will cross-check the connections between hot, neutral, and ground.
I blame the difference between color codes of AC and DC circuits. Most DC circuits are "Negative Ground" and black is the "Negative" wire, so it gets connected to the chassis. Power supplies are both AC and DC, so the white wire is ground on one side and black is the ground on the other side, if you connected black to black you'd energize the case.
I tried explaining this to an ELECTRICAL ENGINEER who couldn't figure out how to wire up a motorcycle. Seriously, he kept saying stuff about the stupid motorcycle company hooking up all the hot wires to ground and he was trying to fix it (he was actually converting it to positive ground and couldn't figure that out). The thing is, this guy designed control systems for manufacturing and it was all AC and wiring diagrams in his mind.
