Question PSU slow fan, loud noise on start up
The voltages inside a psu are potentially lethal. Unless you are compenant to pull apart a psu and replace the fan, don't do it.
What's happening is dirt has gotten in the bearings or the 'grease' has gotten out or a combination of both leading to thicker than normal grease, which thins out with heat. 2-3 restarts is currently enough to have the fan create enough friction to 'melt' the grease and let the fan spin as it should.
Fan + friction = reduces lifespan. Friction creating heat = burned out motor/contacts = reduces lifespan.
There is no 'temporary' solution or fix, there's only the waiting period before the fan fails fully and the psu overheats and dies before you know it's happening because you are in mid game with headphones on or high rpm case/cpu/gpu fans drowning out the sudden stoppage and loss of minor fan noise from the psu.
The only thing you'll notice is a small flash of light, a funky smell from the pc and a glaring black screen. And, the power button does nothing.
Replace the psu or change the fan. Your choice, but better be done before the psu dies as there's always a chance it'll take out something else when it goes, and the cheaper quality the psu, the exponentially higher the chance.
My case doesn't have a grill above, is it okay to buy a PSU with the big fan?
The grill shown in the video isn't a grill, it's part of the case lol. That's the exhaust port. From the looks of it, it's a pre-built sff pc, mini-tower and the psu is most likely a TFX form factor, in which case you'll pretty much need an exact replacement.
For that, you'll need the exact brand and model/year of the pc.
Yes the psu came with the case other parts were picked. So to replace this I need the same psu? (I still think it will work with other psu tho, it has screws in it, its not sticked in the case)
