PSU Voltage out of normal range
Aeglos
Commendable
Mar 31, 2016
Hello folks
I've been experiencing blue screens of death and sudden shut downs since last weekend. Tride many diagnoses and notinhg seemed to explain it. Until I got Everest and Speedfan to see how my psu voltage is.
Readings are almost the same in both programs. This is the big problem....
Vcore1 1,02
Vcore2 1,14
+3.3v 1,60
+5v 5,05
+12v 4,74
-12v -4,13
-5v -0,78
+5v 5,54
Vbat 3,39
GPU Vddc 0,95
As I am realy a newbie to psu problems, I would like you to tell me how screwed I am. Because I can't afford to change psu this month and I really need my pc in my work.
Thank you for your attention
With a desktop pc and power supply
You can use a volt meter (multi meter) on dc range probbably 20 volt range
Find a spare molex connector it has red black black yellow wires
Red black should be 5.0v and yellow black 12 v. Tolerance 5%
Or go into bios (uefi) and look at voltage, temperature and fan speed page
This will be under light load
Using a multi or volt meter you can check voltage when running a heavy load on pc
Regards
Mike Barnes
If you are getting BSOD and sudden shutdowns, something is not right. A good chance it is your PSU. As said, the voltage readings that are being reported are wrong. If your PSU fails, it "could" take out other components with it. So you are putting your computer at risk while you save up for a QUALITY PSU. (You didn't post the make and model of the PSU, so we are assuming it is a low quality one).
Here is the Tom's PSU Tier list link:
http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
AMD Phenom II X3, 2600
ECS A785GM-M
8GB(4+4) Kingston DDR3-1333 8-8-8-22
GPU AMD Radeon HD 5800
PSU Thermaltake TR700 (TR2-700) 700W
HD-1 Western Digital 250GB
HD-2 Seagate 500GB
Thank you but I've already done that. Just forgot to tell. 5v is Ok in the HWinfo but 12v does not appear at all.
Hey people
Can it be my memory slots? I've changed those two memory sticks from slot #1 & #2 to slots #3 & #4 and my PC is on 3 hours straight without BSOD or Shutdown.
I'll try some stress tests to see what happens...
Folks,
I've bought a multimeter and run a voltage test in every single one of my PSU connectors.
12v => 12,53/12,54
-12v => -12,59
5v => 5,03/5,04
3,3v => 3,37
-3,3v => -3,37
stand by => 5,12v
Still gotta run some memory tests.... I've run windows mem test with 0 problems but I don't trust the results.
I've run MEMTEST and I get shutdown every time under the 2 minutes mark. I tried swap sticks, place stick in other slots, put only one at a time.... every time under the 2 minutes it crashes..... full crash. No BSOD, no shutdown+restart. Only full shutdown
Maybe it's the motherboard.
I've already tried with only one stick, for both. Tried put in slots #1 and #3. Same result. Shutdown under 2 minutes.
45 celsius idle
75-78 celsiu load
(i live in Rio, and Its 30-35 celsius these days só Its normal to get these idle temperature)
I can't remember but the shutdown sometimes happen without considerable load or High temperature. Sometimes with 53 celsius.
