Hey, I'm new to this forum and I'm also inexperienced in pc building. I have searched old threads to see if there was an answer to my problem, but I can't find a solution. I also don't know if this is the correct category put this in so sorry in advance!
I recently bought a new mobo, cpu, ram, psu, and ssd. I reassembled my parts, but the pc wouldn't start at all. I learned that it only starts when the 8pin connecter to the CPU wasn't plugged in. All the fans that were plugged into the motherboard worked fine including the gpu and CPU fans, but whenever I would plug in the CPU 8pin connector to the motherboard nothing would happen when I tried to power up. My new motherboard does have a debugger that shows that the processor isn't being detected, which makes sense since no power is going to the CPU.
I was wondering what you guys think, is this a dead processor, a damaged motherboard, or even both?
(I also used an older power supply to test it and it had the same result so i don't think it is a faulty psu)
Specs: CPU: i5 7500
Mobo: MSI B250 krait gaming atx motherboard
Ram:Kingston Fury 8gb (1x8) ddr4 2400
GPU:GTX 750
Storage: 1tb 7200rpm hdd& 240gb ssd
https://pcpartpicker.com/list/gkrXr7
Thanks in advance guys!
Specs: CPU: i5 7500
GPU:GTX 750
