I build my new rig. Since some days m facing a problem with my Psu. when i turned on the system Cpu fans spins a little then stops.
System power switch not work..until i remove and replug the power cable...some time its works fine but system shuts off suddenly after 2-3 min without showing any error.
i also checked my psu on my frnds computer. Same trouble continues...what should i do.. what happen to my psu...it ran fine only for 12 days...
My Config..
Amd FX8350
ASUS M5A99FX PRO R2
Corsair Vengeance 4gbx1 1600mhz
Corsair VS550
My Config..
Amd FX8350
ASUS M5A99FX PRO R2
Corsair VS550
