Hello,
I installed my Kraken X63 AIO today, and after booting up the first time, I used the NZXT CAM software to adjust the pump speed curve, and it worked very well.
However, after booting up the PC again a few hours later, pump speed is stuck at 100% (even if I change it in the app), and liquid temp shows 0 degrees, as seen in the screenshot below.
The AIO seems to be working, as CPU temps are low even under load. Any help?
I tried reinstalling the software, rebooting my PC, doesn't work. Note that, interestingly, I can change the RGB on the AIO. But not the pump speed. I have my pump plugged into the CPU_FAN slot on the motherboard.
