push and pull help
algaceburator
45
What sup guys. i have a question about push and pull system. Few days ago i installed aerocool fan control panel and i just ordered new corsair pwm high performance series fans. I decided to change into both same fans because currently i use 2 different fans. Can i plug main fan (first fan) to cpu fan connector in motherboard and another to fan controller.. Or i have to plug it into sys fan connector in motherboard? My fan controller support 4 pin connector's as well. for me would be easier to plug into controller otherwise i need to take off my graphic card, because i use sli (6slots use). As i know all 4 pin must be pwm or in fan control panel is differently?
Also if i connect to fan control panel do i just leave with standard speed? I dont know how sys fan connectors work in motherboard do they control speed as cpu fan connector or it runs on standard fan speed.
