As you might know, the h115i pro platinum has a usb cable that connects to the mb and the water pump. I fixed the water pump on the cpu and then when plugging in the usb cable into the water pump, I had to apply some force. Could this have moved the water pump or caused any damage?
Thanks!
Thanks!
