putting a 2*6 pin pcie to a 8 pin slot
Fairybub
Commendable
Sep 24, 2016
26
So I had this gpu now for quite awhile (hd 5850) which is pretty old and am now considering to buy a new gpu (rx 470). I want to buy the xfx rx 470 dual fan triple x edition (either that or HIS Ice qx2).
I was searching online to find one and then I found the Sapphire Rx 470 Nitro + oc which need an 8pin pcie (unlike the xfx,his,power color red dragon that uses 6pin) which I find very cool. but since I am using the hd 5850 which requires a 2*6 pin, that's all I have. no 6+2 or 8 pin pcie.
my question is. Can I put a 2*6 pin in a 8pin and leave the other 4 just laying outside. or should I just buy the version which only needs a 6pin.
Thats not right. If your psu has multiple 6 pin pcie plugs but not a 8 pin or 6-2 pin pci e plugs does not...
The motherboard provides up to 75 watts through the PCIe x 16 slot. A 6 pin PCIe plug is rated up to 75 watts, and an 8 pin PCIe is rated up to 150 watts. PSUs with 6+2 pins connectors are rated up to 150 watts.
It seems your power supply doesn't meet requirements to run a card that needs a 150 watt PCIe cable.
Can you put a 2*6 pin in a 8pin and leave the other 4 just laying outside? That sounds like a good way to short circuit the system and cause a fire.
you need to buy a dual 6-pin to single 8-pin adapter
or simply buy the single 6-pin version
You can get a 2x6 pin adapter to an 8-pin, but it's only recommended in case of an older-but-decent-quality power supply that just doesn't have the connectors -- it happens occasionally -- and for that, we'd need to know exactly what PSU you're talking about.
Hmm every card I ever purchased came with them, but it has been a while since I have purchased an ATI card. Last was a hd 5870. I think I have one laying around from my latest Nvidia purchase and if I do and I'll does not get one with his GPU purchase and needs one, it's his.
I meant I have 2 pieces of 6pin pcie. sorry if you didn't get that
ok thx for understanding my mumbo jumbo question. that's the answer I was looking for. another question. xfx rx 470 triple x edition dual fans or his ice q x2?
Thats not right. If your psu has multiple 6 pin pcie plugs but not a 8 pin or 6-2 pin pci e plugs does not mean you can not run a 8 pin card. You just need the adapter. Thats why most cards come with the adapter. You will not short anything out if you use the adapter.
I agree with that.
