I'm putting my new build together--cpu, motherboard--- ect. ect....but using my existing hard drive. Should I format the drive prior to installing everything or put it all together and then put the windows cd in and let it do it then?
Also when should I put my motherboard cd in the manual says as soon as I boot up but I tend to think they mean after you have installed windows. Or does it need the motherboard cd for something right away....This is my first build.....
