How do i check thatMore information needed.
What are you trying to do?
The message is saying that you do not have the necessary access rights to the target network.
The version doesn't matter if the target isn't configured to accept incoming connections, as is the case here.
Ok i will try thatThe version doesn't matter if the target isn't configured to accept incoming connections, as is the case here.
You still haven't told us exactly what you are trying to do, and why.Ok i will try that
Still same messageThe version doesn't matter if the target isn't configured to accept incoming connections, as is the case here.
I am trying to remote into computerYou still haven't told us exactly what you are trying to do, and why.
Obviously. However, where is this computer in relation to the terminal, and have you been granted access by the owner (if not yourself)?I am trying to remote into computer
What steps, specifically, have you taken to ensure that the target is properly configured for remote connections? Keep in mind that we out here cannot see your system/s and have to rely on you to supply all of the details, leaving nothing out if you want help.Still same message
I havent i dont know how to check these thingsWhat steps, specifically, have you taken to ensure that the target is properly configured for remote connections? Keep in mind that we out here cannot see your system/s and have to rely on you to supply all of the details, leaving nothing out if you want help.
