My ASRock 970 extreme 4, has various fan outputs. Two of these are 4 pin pwm. There is one pwm for cpu fan, and one pwm for chassis fan. The secondary cpu fan connector and all other chassis fan connectors are all 3 pin.
Until now, my CPU fan has gone to the cpu pwm, and my chassis fans have been controlled by the chassis fan pwm.
Just had an Antec Mercury 360 through in the post. Looking at it, the fans daisy chain to a 4 pin pwm connector. The pump goes to two connectors. The first is SATA, for pump power. The second is a 3 pin, presumably for monitoring.
Presumably it's a good idea to have the pump monitor wire connected to cpu pwm, to shut everything off if the pump fails. If I do that, how can I control the radiator fans with pwm. The only options I can think of are: a) connecting radiator fans up with chassis fans. Fans will always go at same speed as chassis fans. b) connecting monitor wire to cpu fan 2 (3 pin) for monitoring but won't shut system off. c) Radiator fans to cpu pwm. System won't shut down if pump stops.
Ideally, the motherboard would control the speed of the radiator fans based on cpu temps, but shut everything off if the pump fails. I can't think of a way around this.
If your board is the same as mine, the pwm chassis fan header is located next to the big motherboard power connector.
