PWM Fan Splitter Black
cash is not a proble, i just dont like the stuff that doesn't work. you know waiting days after days to get something that really work. i will try this one, you can still give advice.
Yeah, i feel you there buddy, ordering something from the web and then the stuff is bad..
I'm pretty sure though, that it will work perfectly fine. If really doesn't work--> warranty. But if it does work, which it will likely do, you wont find that much of a difference with another company's same type of cable.
