PWR_FAN connector on MB: maximum current draw?
Tibrocks
Commendable
Jun 28, 2016
18
Hi all,
Got the AMD 970 MB from Gigabyte and planning to hook up 2 fans on a single fan connector:
2x Arctic F12 Pro + in line resistor for each (to reduce speed/noise), connected to a Y split fan connector on the PWR FAN from the MB => my question is, will 2 fans and 2 resistors draw too much current from a single MB connector?
can this damage the MB?
Thanks!
You will still be fine. It is perfectly fine to run run 2x 5 watt fans off 1 header. the issue comes in if you run 3 fans off the same header.
Most fans are 12v at 5 watts at peak loads.
I know they lower the voltage but what about current? they could be 2 watt resistors (can tell as they are covered..)
Thanks! will test it today, just wanted to make sure it wouldn't damage the MB
