Finished my E5200 OC build (just idling for the moment, drive unformatted).
I'm just wondering if the following quad boot is possible:
1. I have XP pro 32bit I will install this in its own partition.
2. I Pre-Ordered Win7 upgrade from XP pro - Can I install the 32 and 64 bit versions in two separate partitions?
I read that a Win7 upgrade from XP has to be a clean install and that it ships with 32 and 64 bit versions. I would like to check them both out without giving up XPpro just yet. This saves me the hassle of re-installing each time I want to check out a versions compatibility with older software.
3. Install Ubuntu - no problem with this, but now I would be at a quad boot.
Has anyone given this some thought, or tried it?
Thanks
Thanks
