Question Quality 240mm AIO Cooler for ITX Gaming Build
nexuslotus
63
I'm doing gaming ITX build with 9700K. Money is not an issue.
(1) My case fits Noctua NH-D15, one of the best air coolers in the market. Would that be sufficient enough to cool this CPU with no OC?
(2) Which 240mm AIO cooler from major brands would you recommend to put into ITX build? I'm looking for the one with shorter and/or flexible tubing. I tried to use Corsair H100i Pro but the tubing is too rigid and long even though I still managed to fit in by putting excessive force on bending tubings. What are tubing's thickness and length like for brands like NZXT or EVGA for 240mm compared to Corsair H100i Pro? Information on tubing's thickness and length are not listed in the specifications. If anyone has experience in this, please enlighten me!
